If fax line or telephone line is in, the MFP won't boot up. After the loading bar it gets stuck in a black screen.
If you plug in the fax after boot, fax works fine.
I tried the factory reset and think it's time to order some parts.
I'm not sure if this is a formatter issue or just the fax board causing the problem.
What do you think?
What do you think?
