Error 79:04 HP designjet 7100
  • fbkhan3
    • May 2012
    • 421
    [Error Code] Error 79:04 HP designjet 7100
    Dear Techs
    hope you all doing very well,Kindly see attached snapshot , when boot process reaches to 20 percent this error will pop up on main display
    is it related to Disk Drive failure ,Service utilities are not accessible, can't upgrade the firmware through Network,do i need to replace Hard disk if some could help me with part number ,or New formatter will be a fix?
    Thank you very much and Appreciate your help and support.
    Regard's
  • Lance15
    • Jun 2015
    • 1088
    • fbkhan3
      • May 2012
      • 421
      Re: Error 79:04 HP designjet 7100
      Thanks a bunch lane for detailed reply.
      I don't find anything like Diagnostics Boot Mode in service manual can you be kind enough to write that.
      as i earlier said Service Utilities menu are not accessible because machine of the error code.
      Thanks for help and support.
      Regard's
      • Lance15
        • Jun 2015
        • 1088
        Page 91 of the service manual - Entering the Service Test menu
