Designjet T790 at 93%
  • bunnthebody
    • Oct 2008
    • 38
    I am working on a T790. It had a bad service station which I replaced. The manual told me that I had to reset calibration flag and drop sensor first.
    Now it stops at 93% and clicks. Can I put the old drop sensor back in. I cannot get in to service mode at this time. I only have one of these and do
    not know a lot about it
    Thanks Roger
  • Kiran Otter
    • Dec 2013
    • 1115
    Re: Designjet T790 at 93%
    What's clicking, the service station?
    I would remove the print heads, and then unmount the service station but hold it in position.. not up against the carriage rails but a little lower, and turn the printer on. See if it initializes. If it does, then you've got the service station mounted incorrectly. I've done this more than once.. it's a bear to get it up into position correctly.
    And yes, you can put the old drop detect in, but I doubt it's the cause of the problem.
    Kiran
    • bunnthebody
      • Oct 2008
      • 38
      Thanks for your help. This fixed it.
