HP LASERJET 4250 dtn
  • dannet
    • Oct 2011
    • 22
    [Error Code] HP LASERJET 4250 dtn
    hello
    kindly assist with error codes on hp printer, after replacing fuser membrane it has satrted giveing error codes 50.3
    what could be the problem.
  • theengel
    • Nov 2011
    • 1784
    Re: HP LASERJET 4250 dtn
    It's put together wrong.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4689
      heating element broke when replacing fuser sleeve or it is bad.
      • 1stcavvet
        • Apr 2015
        • 231
        make sure the connectors on the ends of the upper assembly are pushed on all the way and all connectors are clicked together GOOD LUCK
        • Wild Bill
          • Jul 2005
          • 774
          What is a fuser membrane?
          Izzy
          • JrTech
            • Jun 2013
            • 217
            50.3 error is almost everytime, you have the wrong fuser installed. It will fit and covers close but most likely it is cool to the touch. The HP4200 fuser looks very much the same and will throw those errors. Take it out and shake it, if you hear anything loose, return it. Had a tech that constantly installed the HP4200 in the HP4250. What happens when you put the old one back in? Error code? These machines are super simple in design and are for the most part very low maintenance. There are plenty of places to order these but buyer beware. I use a company called Gem Laser in Sterling VA for most of my parts.
            Hope this helps
            • Wild Bill
              • Jul 2005
              • 774
              50.X FUSER ERROR
              For help press
              A fuser error has occurred.
              X Description
              1 low fuser temperature
              2 fuser warmup service
              3 fuser over temperature
              4 faulty fuser
              5 incorrect fuser is installed
              6 open fuser circuit
              Izzy
              • Wild Bill
                • Jul 2005
                • 774
                Really wth is a fuser membrane
                Izzy
                • theengel
                  • Nov 2011
                  • 1784
                  I think he means film.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4689
                    Can't be wrong fuser if he replaced just the film (membrane)
                    • subaro
                      • Oct 2010
                      • 1274
                      Here you go Bill
                      ˈmemˌbrān/
                      nounANATOMYZOOLOGY
                      [COLOR=#878787 !important][/COLOR]
                      • 20 year tech
                        • May 2014
                        • 577
                        Insane in the membrane !!
                        • Printerdude
                          • May 2015
                          • 119
                          Maybe he meant the heating element. If so, you may have put it in backwards or it's for a different voltage printer or model. Replacing the correct fuser will fix your issue.
