HP LJ4250 fuser
  • tufbnme
    • 493
    HP LJ4250 fuser
    I am sick to death of fuser issues with the 4250. There are so many different types (reman, refurbed, new compatible and new) I have tried all and they just don't go the distance.
    Can someone please refer where I can get good, new OEM fusers?
  • JR2ALTA
    • Feb 2010
    • 2031
    Re: HP LJ4250 fuser
    LPT Home Page - HP LaserJet and Lexmark Parts
    great tech support as well
    • tufbnme
      • 493
      Re: HP LJ4250 fuser
      Thanks I'll give them a try.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Re: HP LJ4250 fuser
        Originally posted by JR2ALTA
        I was going to say the same thing.
        • Iowatech
          Not a service manager
          • 3930
          Re: HP LJ4250 fuser
          You should get the maintenance kit. Turns out you generally save money if you do that rather than just get the fuser.
          Theoretically, you should still be able to get that from HP. And you'll most likely build up your feed roller reserves that way too.
          • subaro
            • Oct 2010
            • 1274
            Re: HP LJ4250 fuser
            When replacing the fuser unit, i would also replace the black gear on the swing plate assy or the entire swing plate if the white gear is almost gone. The black gear is easy enough to replace with the fuser unit. Also lube the swing plate assy gears with grease containing PTFE.
