HP Laser Jet Pro M451 color Paper feed
  • iscott
    • Mar 2010
    • 344
    Just replaced the paper feed feed rollers on this machine. Used OEM rollers. Have never done this repair, but all seemed to go well. Now is jamming every time for multiple pages. One page docs come out fine. second page is jamming. Cancel the job and the page that is supposedly jammed ejects with no problem. No roller marks or dog ears.
  • Iowatech
    Not a service manager
    • 3930
    Re: HP Laser Jet Pro M451 color Paper feed
    When you run a print job with more than one page, where does the jammed sheet stop?
    • iscott
      • Mar 2010
      • 344
      At the paper feed rollers...
      • Lance15
        • Jun 2015
        • 1086
        Have replaced MANY of these rollers (RM1-4426). Haven't had to replace the small seperation roller, though. Maybe the one your working on also needs that roller replaced (RM1-4840)?
        • iscott
          • Mar 2010
          • 344
          Replaced both rollerS.
          • Lance15
            • Jun 2015
            • 1086
            Can you hear if the roller is rotating to try and pick up paper? Maybe the pickup roller isn't completely seated and is grabbing two sheets accidentally? Haven't run across issues replacing these, just trying to bounce ideas around.
            • SwisSeV
              • Jan 2016
              • 307
              Check that the pick up solenoid isn't getting stuck and is engaging, the pickup will continue to turn and pick up multiple pages and that will cause a jam state.
              • theengel
                • Nov 2011
                • 1784
                Make sure there's nothing stuck in the duplex area. I've had that throw me off once.
