Hp m4345mfp booting up issues +
  • cucuklotz
    • Mar 2007
    • 611
    Hi
    About 75% of the time when you turn on machine the machine freezes up at the final booting up stage( 6Of 6).if it goes into ready
    the INITIALIZING SCANNER message stays on and you can only to machine. Also sometimes when printing a PRINT JOB it feeds an extra cycle or two pages(blank)but separate feeds that force jam in machine at transport and exit.I saw some bulletins on INITIALIZING SCANNER issues,but do you think all these problems all stem from one cause? or do you think I have multiple issues on machine,I don't service many of these.
    THANKS FOR ALWAYS HELPING ANDY
  • theengel
    • Nov 2011
    • 1784
    Re: Hp m4345mfp booting up issues +
    I would treat all of these as separate issues.
    • Lance15
      • Jun 2015
      • 1089
      Start with the hanging at 75%. Use this link to troubleshoot the booting issue:
      Go from there. If I come across the CSN one, I'll add it. Can't find it at the moment.
      • cucuklotz
        • Mar 2007
        • 611
        Hi
        Thanks for all; the help and providing me with some good links,Im waiting for customer to scheduele call.When customer called originally all they told me was that there was a jam in machine they couldn't find.So I was in the dark about the machine until I got there.It took me an hour to get a sense of what was happening,to get a feel for the machine and problems.It also took so long when it would not boot up 3 of 4 times,I think they thought I would have all the answers in a hour,so they havnt gotten back to me yet.
        ANDY
        • subaro
          • Oct 2010
          • 1274
          Try replacing the hard drive or do a format of the hard drive.
          To perform a hard-disk initialization
          1 Turn the MFP off and then on.
          2 When the memory count appears on the control-panel display, press the right-hand side of the
          START button until all three LEDs are lit. Release the START button.
          3 Press 5 one time. INITIALIZE DISK appears on the control-panel display.
          4 Press 6 one time. A series of asterisks appears on the control-panel display. Wait for the MFP to
          complete its initialization sequence.
          the above is for the 4345 which should work for the M4345
          • austonrush
            Sharp & HP Tech
            • 242
            Did you try updating the firmware? Firmware is available on HP's website. I would try that first.
            What if you go into diagnostics have you tried any of the scanner tests in there?
            My repair process for your problem would be the following, do in in this order:
            - Update firmware
            - Scanner tests in diagnostic mode (make sure the scanner bulb turns on etc)
            - If all looks good in those tests Cold Reset (You'll lose all your settings I believe)
            - run a disk initialization
            - If still acting up replace the formatter board
            - At last Replace the Scanner Assembly
            If none of that works hit it with a sledge hammer and throw it out! lol
            • austonrush
              Sharp & HP Tech
              • 242
              I just saw you also have a feed problem. That is likely a bad solenoid/ clutch. Pull off the side cover and the paper pickup in action.
              This is an old machine. I'm not sure it is worth fixing all these different issues .
              • subaro
                • Oct 2010
                • 1274
                Have repaired and refurbished quite a few of these and the previous models the lj4345. They run great and the engine style is same as the LJ4300 series. Sometimes these machines just need a good overhaul and checks and lube and go back in service and wait till the next part wears. As usuall, the swingear assy, fuser and with this one the control panel craps out at times. These machine are worth fixing . they also comes with a nice little finisher.
                • Iowatech
                  Not a service manager
                  • 3930
                  Originally posted by cucuklotz
                  Hi
                  A while back, someone shared what those stages meant. I even bookmarked that as a permanent link.
                  Then I changed browsers and lost the link.
                  I may still have the link in one of my older browsers, I'll take a look.
                  But it wouldn't hurt for you to search for that on your own too, because it is here.
                  • faxman28
                    • 435
                    boot_progress.pdf With your failure to boot at stage 6 and the intermittent scanner init error, replaceing formatter box and scanner control would be the way to go,hps' next step is to replace the complete scanner unit. maybe not very cost effective.
                    m4345scanerinit.pdf
