HP color 4700 Etb
  • Users Tech
    • Nov 2013
    • 85
    HP color 4700 Etb
    Hello all,
    Which part of the Etb that causes this problem in the attachment? Are there any solutions (parts cleaning maybe) other than replacing the whole etb? What causes this to happen?
    best regards,
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Re: HP color 4700 Etb
    Why the belt? The black streak would also be affected. I have seen these belts look pretty bad and still make a good print. Are you using aftermarket cartridges?
    • Lance15
      • Jun 2015
      • 1073
      +1 fixthecopier
      • Users Tech
        • Nov 2013
        • 85
        Yup, it is a problem of the etb because when i replace it with another etb the prints are perfect but when i put it back again the problem comes back. i also installed it on another HP 4700 and the problem comes out. please see attachment. what do you think caused this problem? is there a remedy or another solution aside from replacing the whole etb?
        ty
        • fixthecopier
          ALIEN OVERLORD
          • 4714
          You should replace it.
          • theengel
            • Nov 2011
            • 1784
            Each color has its own little transfer unit. Sometimes one will go wrong while the others don't. I don't know of any way to fix this without replacing the whole transfer belt.
