Color Laserjet CM2320 not picking up
  • theengel
    • Nov 2011
    • 1784
    Last month, I replaced the pu motor on this thing because of intermittent jams. It worked fine for all that time.
    Yesterday, the customer was getting a "remove packing from cartridge" error. I swapped color cartridges, as suggested in other threads, then swapped them back. The error went away, but now I can't print.
    When I print (internal and external--or even an engine test), the developer & drum motors go on, I hear some clicks (probably from the transfer unit), but the pickup motor never engages. It'll keep doing that, the motors starting and stopping, without ever actually giving a jam code.
  • Wild Bill
    • Jul 2005
    • 774
    Re: Color Laserjet CM2320 not picking up
    Firmware?
    Reset factory settings hmmm strange problem.
    Izzy
    • Lance15
      • Jun 2015
      • 1089
      Solenoid? Main Drive?
      There really isn't much that can be replaced on these units. I'd suggest main drive, but, unless you can find a junk machine or someone who has parted one (eBay), the main drive isn't orderable.
      • theengel
        • Nov 2011
        • 1784
        I was thinking DC controller, but I really have no idea. Like I said, the actual feed motor (which I replaced a little while ago) isn't turning at all. I can't, from the manual, tell where the drive comes from. These HP manuals are getting worse and worse.
        • Wild Bill
          • Jul 2005
          • 774
          My thought on these is if it looks like a lot of labor and an expensive part its time for a new machine.
          The hard part is getting customers to see this and if its on contract well then Id look on ebay for a replacement.
          Izzy
          • theengel
            • Nov 2011
            • 1784
            Bringing this up again because I have yet another machine doing the exact same thing. The machine keeps cycling, as it's trying to print, but the PU motor never turns. And it never gives me a jam code--the machine just continues to "cycle"... I hear all kinds of gears and motors turning until I turn it off. Has anyone else seen this?
            • Lance15
              • Jun 2015
              • 1089
              CP2020, CM2320, M351, M375, M451 and M475 MFP Series - Remove Shipping Lock error message on con.pdf
              • Lance15
                • Jun 2015
                • 1089
                Here's that first document they reference in that document I posted.
                CP2020, CM2320, M351, M375, M451, M475 and M476 MFP Product Series - Remove Shipping Lock error .pdf
                • theengel
                  • Nov 2011
                  • 1784
                  This has to do with the cartridge lock problem, but that's not the problem I'm having.
                  • theengel
                    • Nov 2011
                    • 1784
                    Bumping this up to see if anyone found a solution. What was actually happening, was a solenoid in the main drive unit (I think). But I it's in the middle of a giant gear assembly, and I'm too scared to just take it apart.
                    I've seen three like this in the last year, but the gear assembly wasn't for sale.
                    • Lance15
                      • Jun 2015
                      • 1089
                      Got a dumpster?
                      • theengel
                        • Nov 2011
                        • 1784
                        Really? It's that bad? Those a re nice little machines. They're getting kind of old though. I remember seeing the main drive assembly at a parts site, but it said it was "refurb" and I believe they just pulled it off an old machine. But I'm hoping someone started actually refurbing them.
                        I like those machines because the doc feeders take a lot more punishment than most other small volume machines.
