HP P3015 duplex jams error 13.12
  • Hoosierdaddy
    • Oct 2016
    • 181
    Jams only when duplexing, as paper is getting pulled in for 2nd side. Machine has 340K. Fuser is at about half of its yield. It is intermittent for know. Any suggestions or has anyone experienced this before?
    Happy Thanksgiving
    Hoosierdaddy
  • Lance15
    • Jun 2015
    • 1087
    Re: HP P3015 duplex jams error 13.12
    Pickup roller good? OEM toner? Paper tray set EXACTLY to LTR (to far behind hash mark, intermittent pick up; to far forward of the hash mark, it's to tight against the sep pad and won't pick up)?
    Never experienced this error personally.
    • Wild Bill
      • Jul 2005
      • 774
      Happy Thanksgiving
      Hoosierdaddy
      There is a gear on a swivel on the exit drive assembly. Pull the fuser out and carefully give it a bit of oil to make sure it isnt getting stuck when it duplexes.
      Izzy
      • Hoosierdaddy
        • Oct 2016
        • 181
        I will do that. Thanks for the reply
        • Hoosierdaddy
          • Oct 2016
          • 181
          i guess we have to assume that you have checked the duplex path for obstructions? have you cleaned any rubbers rollers in the path? have you run the sensor test for the paper path?
          Yes all the sensors are clean and no obstructions and rollers are very tacky and clean.
