20.0004 in error log.
  • Dadofmykids
    • Dec 2016
    • 27
    HP LaserJet Pro MFP M521DN with Error 20.0004 in error logs.
    Error 20 is memory error. What does the 0004 mean?
  • Lance15
    • Jun 2015
    • 1087
    Re: 20.0004 in error log.
    From this page:
    "The printer does not have sufficient RAM to process the fax job."
    • techie0419
      • Apr 2017
      • 36
      I've seen this same error on both a M426 and M477.
      The solution I've found (trial and error with HP on the phone the first time, but it worked in both cases), is to go to Setup > Service > Fax Service > Clear Saved Faxes. The users were then able to send and receive faxes as usual.
      Prior to "Clear Saved Faxes", when trying to send even a one page fax, the machine would pass the paper through the ADF, and immediately give a message on the display that there was insufficient memory. After going through that procedure, it was a noticeable difference in that it would begin the normal fax process rather than display anything about the memory.
