hp 4300.pdf
I am currently working on an HP 4300 and am having this trail edge issue with the paper from trays 2 and 3 only, it prints perfect from the bypass tray ( full print). The printer was past maintenance when I arrived so I installed a maintenance kit, I thought maybe the fuser was causing the issue or possibly the transfer roller, feed rollers, being the printer was 70k past due. After replacing the kit I still had the same issue, swapped out toner cartridge..same issue so I thought I would try replacing the feed roller assembly ( RM1- 0012-000), would resolve the issue... no dice. My thought if it is a voltage issue, I would have the same problem though the bypass tray. I'm going to pick up the printer on Friday and pull out the drive section, clean and lube. Any help or ideas are appreciated.
I noticed a line on the right side of the PDF, that is caused by the scanner I used to post the pic, the print is clean.
