hp officejet pro x576 "problem with printer or ink system"etc. message
  • tmw
    • Dec 2013
    • 260
    It's rare I have to look at these things,so I only know so much. I was sent to an office with two identical machines. I gather that they have frequent power problems,and when they do, they get a message like the one above,which includes no error codes. The first time I went there, eventually I concluded that it was caused by a bad ink cartridge.They had some coming on order, and I got both machines working on an empty black cart.
    A few days later they called with one of them having the same message, and two new carts.installed. Power cycling and pulling the plug didn't change anything. I swapped the black carts to see what would happen, and both machines came up and started printing. I would like to better understand what is going on here. The customer asked if there was an easy way for her to reset it, but I couldn't tell her because I didn't know myself. Is there a logical reason why they would do this? I'm not sure what I would tell her. Thank you for any insight someone would have.
  • Lance15
    • Jun 2015
    • 1089
    Re: hp officejet pro x576 "problem with printer or ink system"etc. message
    OfficeJet Pro X series (X451dn, X451dw, X551dw, X475dn, X476dw, X576dw Printbar Failure for Flex.pdf
    Check this PDF.
    • tmw
      • Dec 2013
      • 260
      Thank you Lance for your reference material. Although these printers are out of range of those serial numbers, and there are no error codes shown.
