colors prints half page LJ CP 5225
  • kaborwen
    • Feb 2010
    • 146
    [Misc] colors prints half page LJ CP 5225
    Hi all,
    I have an LJ CP 5225 printer that prints color items only on te half of page. The black of the same page, are correct. When doing an interrupted print, the image appears clearly on the blak drum and the black magnetic roller. But on the three colors ( C, M ans Y), the image appears on the magnetic roller but not on the drums.
    An idea please!
  • Lance15
    • Jun 2015
    • 1089
    Re: colors prints half page LJ CP 5225
    Are HP toner cartridges being used or aftermarket?
    • kaborwen
      • Feb 2010
      • 146
      Second attached file with print direction.
      • kaborwen
        • Feb 2010
        • 146
        See attached file please.
        NB: My scanner is not very good.
        • Lance15
          • Jun 2015
          • 1089
          Looks like it could be a belt issue.
          • Iowatech
            Not a service manager
            • 3930
            I agree with Lance15, it does look like an ETB problem.
            Also, thanks for letting us know that your scanner isn't the best, otherwise I would have included that the machine's toner cartridges were worn out, as the black bar on the image you shared really doesn't look good.
            If the arrows on the image you shared show the direction of print paper travel through the machine, please ignore my next sentence, as it is wrong.
            It could be a problem in the laser area, maybe with the polygon mirrors being contaminated.
            • kaborwen
              • Feb 2010
              • 146
              The arrows are showing print direction. I do print with up cover open, and i saw that the belt running well.
              • Lance15
                • Jun 2015
                • 1089
                The belt rotating is immaterial. The belt has 4 charge rollers underneath (one for each color). If they aren't "working right", there will be image defects.
                • kaborwen
                  • Feb 2010
                  • 146
                  OK thanks. I will check and let you know.
                  • theengel
                    • Nov 2011
                    • 1784
                    I had this problem with a machine, and never did quite figure it out. It was almost exactly the same as your... except different lengths where the colors disappeared. I had replaced the transfer belt and it didn't change anything. Although, I didn't check the mag rollers in the stop test... just the drums. It's really strange to me that the mag roller can show the image and the drum not. The only reason there would be an inverse image on the mag roller, is if that toner had gotten on to the drum. I can't think of ANY other way for the image to appear on the mag roller.
                    Anyway, someone had sent me some PDF's with some descriptions of certain plastic bushing that are wearing on these machines causing this problem. I'll see if I can find them and post them. I had dropped that call because I already had a ton of time into it, and it was pretty far away from my home base. The description of the possible fix is a pretty big job, and I don't know for certain that it would work, so I didn't want to step in anything so big.
                    • theengel
                      • Nov 2011
                      • 1784
                      Ok,
                      Here's that old thread:
                      http://www.copytechnet.com/forums/hp...ghlight=cp5225
                      • theengel
                        • Nov 2011
                        • 1784
                        OK-- I got it. If the color image is only appearing on half the page:
                        The color toner unit turns in the beginning. Then, it suddenly stops turning. The image that it had produced, is transferred onto the drum, and from the drum, it goes onto the paper. The drum continues to turn throughout the print process, but the dev roller isn't turning. To the very last thing that the dev roller transferred is still showing there, because it's no longer rotating, even though the drum is rotating. That's why you can see the image on the mag/dev roller, and not on the drum. My guess is that if you pulled the toner ctg out after the print (without stopping in the middle of the print), you'd still see that image on the dev roller.
                        So the problem is probably in your developer roller drive. Some gears are stripped or something. I believe that possibility is described in the other thread referenced.
                        • kaborwen
                          • Feb 2010
                          • 146
                          Thank you for your answer. I disassembled the gears block and found three small broken plastic. But I can not find their exact source. Your PDF will help me a lot. Thank you in advance.
                          • kaborwen
                            • Feb 2010
                            • 146
                            Thanks you very mutch. It's help full.
                            There are actually three (black, cyan and magenta) that are broken. But, what I do not understand is why the black is broken and printing well compared to the yellow that is not. I want to be sure before order parts one time.
                            • theengel
                              • Nov 2011
                              • 1784
                              Those broken pieces might not be why the colors disappear. It might be the dev. drive gear assembly--worn gears inside that. If you replace that, make sure to follow the manual on lining up those gears before installing.
