HP LJ 4200 envelope feeder
  • copyman
    Owner / Technician
    • Sep 2005
    • 4750
    I put new feed roller in this envelope feeder and it will feed one envelope with no problems but if you put a stack it won't feed at all. I've clean all the other rollers, one way bearing gears, etc.
    Any ideas appreciated.
    Thanks in advance
  • theengel
    • Nov 2011
    • 1784
    Re: HP LJ 4200 envelope feeder
    You might go to the shaft that the one way bearing is on and clean it and use sand paper to get it roughed up a little.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4750
      UPDATE
      Just wanted to update on fix. After scuffing up both shafts where the one way bearings are it still wouldn't pull in envelopes. I remembered that when I replaced the feed rollers I cleaned the one-ways with alcohol. That was a mistake! Turns out the bearings need the grease to grip the shaft. Put grease back in bearings and working great now !!!
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        One way bearings can be tricky little animals, regardless of brand.
        • ofcourse
          • Jul 2017
          • 6
          Thanks in advance
          Just curious, I have some of these same feeders -- what kind of feed rollers were you using as replacements?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4750
            I posted in an earlier thread that after a lot of searching found out the LJ M600/601 envelope feeder "CE399A" uses same rollers & other parts. They do have part #'s for all the parts in the newer feeder. Figured there had to be parts for these older feeders since they are being sold on the internet as " completely refurbished". Hope this helps.
