Designjet T610 hard drive
  • theengel
    • Nov 2011
    • 1784
    When replacing the formatter/harddrive on this machine, does it matter which hard drive you go with. If the old one had IDE, can you replace it with SATA without any problems?
  • Lance15
    • Jun 2015
    • 1089
    Re: Designjet T610 hard drive
    This may help. I'm not sure.
    T610 New Formatter Design.pdf
    • pebkac
      • Oct 2014
      • 36
      I'm not sure I understand your question, but:
      Either type of formatter should work fine, but you must use a hard drive that's compatible with the formatter. That means if you're switching from a PATA to SATA formatter, you must also replace the hard disk.
