Designjet Z2100
  • theengel
    • Nov 2011
    • 1784
    Designjet Z2100
    Does anyone know if the formatters/HD on these can be swapped between machines without messing anything up. I have a friend with a malfunctioning one (8:11) and I believe it's the formatter. But heck, maybe it's the HD and not the formatter. Either way, can I take parts off my Z2100 in the shop and swap them? What about the main board on these?
  • blasterlws
    • Feb 2014
    • 6
    Re: Designjet Z2100
    You need to get a virgin hdd with blank id . Look on ebay
    • Kiran Otter
      • Dec 2013
      • 1115
      Re: Designjet Z2100
      No, you can not swap drives, but you can swap formatters if you also swap the drives (keep the original drive with the original printer.)
      LPS Computer sells the drives.
      What do the LEDs on the formatter tell you? If LED II is flashing it's likely the hard drive. If not then you may have a different problem.
      Kiran
      • Kiran Otter
        • Dec 2013
        • 1115
        Re: Designjet Z2100
        Erf. Disregard what I said about the LEDs on the formatter. I was thinking of a different model.
        Kiran
