HP laserjet 600 m602 (13.A2.D2)
  • ash_572
    • Oct 2008
    • 523
    [Misc] HP laserjet 600 m602 (13.A2.D2)
    i have the above machine jamming from tray 2 only. half of the page is out of the exit unit with no image on the document.
    tray 2 pickup, feed and seperation rollers have been replaced.
    tray is set to A4.
    swapped tray 2 with tray 3 and still the same.
    cleaned the reg sensor.
    tray 3 prints perfectly fine.
    small white gear between pickup and feed roller looks good with no damage.
    any ideas?
  • ricoh_rockstar
    • Apr 2016
    • 18
    Re: HP laserjet 600 m602 (13.A2.D2)
    Try checking the paper pickup solenoid, sometimes they get sticky and cause the paper to stop halfway through.
    Good Luck!
      tray is set to A4.
      any ideas?
      does the print driver match what is in tray 2? size .. type weight?
      • techwurk
        • 127
        There is an adhesive damping strip on the solenoid arm applied at the factory that sometimes turns to goo and causes the arm to momentarily stick, common on many, many HP printers
        When I started servicing copiers they used toaster ovens for fusers.....I'm old
        • Lance15
          • Jun 2015
          • 1089
          Not likely on the M600 series......yet.
          Had exact issue a couple of months ago. It turned out a flag on the paper feed shaft broke off and wasn't "telling the sensor" the correct state.
          RM1-8424 - Paper Feed Shaft
          I had pictures, but, they've long since been deleted.
          • theengel
            • Nov 2011
            • 1784
            By 'paper feed shaft', do you mean the shaft with the feed roller on it, or something else?
            • Lance15
              • Jun 2015
              • 1089
              • techwurk
                • 127
                Why not yet, I have seen it happening on the 4014/15 series a number of times, same age printers
                • theengel
                  • Nov 2011
                  • 1784
                  The 4015 is the older version of M600
                  • techwurk
                    • 127
                    M600 have been out there for over 5 years, 4014 a little longer. All i'm saying is to check the adhesive strip on the arm, not saying it is the definitive cause
                    • ash_572
                      • Oct 2008
                      • 523
                      Yes. This also happens when I print off configuration reports.
                      • theengel
                        • Nov 2011
                        • 1784
                        So did you check the solenoid??
                        • Wild Bill
                          • Jul 2005
                          • 774
                          LOL yea sounds like the issue cause its blank. Fed an extra sheet right?
                          Izzy
                          • cseodris
                            • Feb 2015
                            • 7
                            I ran into this same problem and determined that the feed roller wasnt lifting off the paper and was causing the next page to "pre load" to the sep roller in the tray. When the next print job or page was was started the sep roller was pinching the paper down and not allowing the paper to get past the tray. Turned out to be a spring on the paper shaft mentioned and pictured earlier had come off somehow and was jammed under the primary roller shaft not allowing the feed unit to retract far enough to stop feeding the paper. I know this post is old but hopefully this will help someone in the future.
