HP LJ 4345 Says open right door clear jam
  • Doug James
    • Jan 2012
    • 935
    [Jamming] HP LJ 4345 Says open right door clear jam
    I installed this machine a week or so ago that this customer bought. When I left it was running fine. Got a call today....The copier starts to copy then says jam. It doesn't even try to pick up the paper. I set the paper to run out of tray 3 and it still says open tray 2 right door. It ran a few but mostly always says open door. I set it to run paper from MP tray and it does just fine... Any Ideas. Appreciate any help...
  • Exceltech
    • May 2012
    • 14
    Re: HP LJ 4345 Says open right door clear jam
    Sounds like something is not engaging at pickup. check separation, feed rollers, some with one way bearings will slip, otherwise it could be a crappy photo-interrupter or something with the drive. Also check to make sure the cassette is lifting high enough. are there many prints on the printer?
    • Doug James
      • Jan 2012
      • 935
      It has 229636 for copy count.. From what I can tell, the feed rollers don't even move. Thinking I have a sensor going haywire too... These type of problems are un-fun lol... Thanks for your response !!
      • 20 year tech
        • May 2014
        • 577
        what code is showing in the event log ? you should be able to view it in the troubleshooting area on that model
        • boscru
          • 31
          spit-balling here without seeing it, but i'm guessing you installed it on a level surface??? i've seen issues where a non-level situation can cause problems on HP door sensors
          the frames are easily flexible aluminum
