I installed this machine a week or so ago that this customer bought. When I left it was running fine. Got a call today....The copier starts to copy then says jam. It doesn't even try to pick up the paper. I set the paper to run out of tray 3 and it still says open tray 2 right door. It ran a few but mostly always says open door. I set it to run paper from MP tray and it does just fine... Any Ideas. Appreciate any help...
HP LJ 4345 Says open right door clear jam
Re: HP LJ 4345 Says open right door clear jam
Sounds like something is not engaging at pickup. check separation, feed rollers, some with one way bearings will slip, otherwise it could be a crappy photo-interrupter or something with the drive. Also check to make sure the cassette is lifting high enough. are there many prints on the printer? -
Sounds like something is not engaging at pickup. check separation, feed rollers, some with one way bearings will slip, otherwise it could be a crappy photo-interrupter or something with the drive. Also check to make sure the cassette is lifting high enough. are there many prints on the printer?Comment
what code is showing in the event log ? you should be able to view it in the troubleshooting area on that modelComment
spit-balling here without seeing it, but i'm guessing you installed it on a level surface??? i've seen issues where a non-level situation can cause problems on HP door sensors
the frames are easily flexible aluminumComment
