PCL XL error CM6040f MFP
  • TayTayTheTechnician
    • May 2016
    • 51
    [Error Code] PCL XL error CM6040f MFP
    Does anyone recognise this error? I got it while trying to print a demo sheet on a CM6040f MFP. it isnt causing any issues, im just curious is all.
    Sent from my LG-LS777 using Tapatalk
  • Lance15
    • Jun 2015
    • 1089
    Re: PCL XL error CM6040f MFP
    Driver issue. Update the driver if possible.
      • May 2016
      • 51
      But i was printing from the machine itself, can you load the driver straight onto the machine? Thats why i found it to be so weird
      • Lance15
        • Jun 2015
        • 1089
        Is it networked? That beast probably is.
        Maybe someone printed while you were printing internal pages?
        PCL XL is the internal name for PCL6.
          • May 2016
          • 51
          I bet it is cause the driver is on the network. I went there cause of a fusing error and i dont want to go down the rabbit hole so to speak, i just thought it was really odd. Oh well. If it ain't broke [emoji6]
