After replacing the trailing cables and thoroughly cleaning the contacts on the carriage and on the printheads the self test indicated all printheads OK and full or nearly full. When the alignment page printed there was no magenta at all. Then an error code was displayed 0C0032 (drop detector not calibrated for all printheads.)
When I replaced just the magenta printhead there was still no magenta on the alignment page and the magenta and CYAN printheads indicated "monitor". Black and yellow still indicated OK.
With these weird symptoms and magenta never printing at all, even when status is OK, is this more likely a problem with the carriage or the electronics module?
All supplies installed are genuine HP.
Many thanks!
Many thanks!
