HP M630 30.03.23 scanner calibration error
  • psteelers
    • Feb 2015
    • 38
    Hi all. I have a HP M630z that has an error of 30.03.23 scanner calibration failure. According to tech support, the web and apparently HP, this is fixed by replacing the flatbed scanner assembly. I have and it didn't. OK, now before I replaced it I had updated firmware, reseated all cables from formatter and to scanner. Even reseated formatter itself.
    After replacement, it booted right up into same error code. I again reloaded firmware, checked all connections and did a scanner calibration just in case. It of course failed. Tech support is suggesting replacing scanner board as you transfer it between scanner assemblies during replacement. A very outside possibility might be the formatter.
    The printer portion works perfectly, just when scanning, copying, etc. You get massive lines down pages. Lines are about 5/8 inch apart with about a 2 inch "smudge" streak down left side.
    Has anyone had any luck with this issue?
    Thanks in advance
    • 22997
    Re: HP M630 30.03.23 scanner calibration error
    Have you cleaned the second side slit glass, and white reference for the second side. You do have to reboot the device to clear the error once it's been cleaned. =^..^=
