hp dj T790
  • 1stcavvet
    • Apr 2015
    • 231
    [Jamming] hp dj T790
    If I attach the cutter to this machine, it goes to the left side after a good print and tries to cut the paper--- travels about 5-6 inches from the left side the carrier stops and shows an 86.10 paper jam,(this is also happening with a new cutter assembly) if I remove the cutter the machine shows no problem.the machine prints and the customer has to manually cut the paper. I was thinking the rear bushing is probably gone and the carrier is dragging in the front -----Looking for any other ideas------ machine is 2-3 years old and hardly gets used
  • theengel
    • Nov 2011
    • 1784
    Re: hp dj T790
    Have you cleaned and oiled the rail?
    If the rail was dirty and causing a lot of resistance, then the added cutter resistance could be the straw that breaks the back and finally throws up the error.
    • Kiran Otter
      • Dec 2013
      • 1100
      Re: hp dj T790
      Wow, I had this EXACT problem recently. I thought it was something to do with the belt so I started to replace it. When I removed the carriage, I realized the belt wasn't even attached to it! The carriage was broken where the two posts that hold the belt to the carriage were. How it worked at all... I don't know. I think this is a result of the end user trying to force the carriage to move, either during a jam or some other time.
      When I showed it to HP, they said yup! They'd seen that before.
      So maybe this is your problem.
      Kiran
      • Kiran Otter
        • Dec 2013
        • 1100
        Re: hp dj T790
        Also, note the correct position for the belt as it threads in the carriage.
        • theengel
          • Nov 2011
          • 1784
          Re: hp dj T790
          Kiran
          I had one break there... but it wasn't moving at all. And I'm pretty sure it broke because the user was trying to force the carriage to move.
          • Kiran Otter
            • Dec 2013
            • 1100
            Re: hp dj T790
            Any update on this, 1stcavvet? I'm curious what you found.
            Kiran
            • 1stcavvet
              • Apr 2015
              • 231
              Re: hp dj T790
              Yup!!! belt attaching area was broken the 2 outer lugs were missing, I took the carrier out of the machine and when I turned around with the carrier in my hand the belt fell on the floor I can't believe it would even print
              • Kiran Otter
                • Dec 2013
                • 1100
                Re: hp dj T790
                Yeah, exactly what I had. Thanks for the update!
                Kiran
                • theengel
                  • Nov 2011
                  • 1784
                  Re: hp dj T790
                  I wonder if there's a way to repair those with some kind of clamp. The next time I run across this, I think I'll try. The problem is that aside from keeping the belt clamped down, those two posts also affect belt size because they make a little curve in the belt.
                  • 1stcavvet
                    • Apr 2015
                    • 231
                    Re: hp dj T790
                    Go on ebay To look at carriers t790, there's a guy in England who invented a clamp like your refering to. he's selling them for around 50.00
