HP CP 2025 Intermittent Black Lines
  • Hoosierdaddy
    • Oct 2016
    • 181
    I have a HP CP 2025 that inter puts black lines accross pages. Have already swapped out toner but no help.
    Anyone ever come across this problem
    Hoosierdaddy
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    Re: HP CP 2025 Intermittent Black Lines
    Post a sample.
    • Hoosierdaddy
      • Oct 2016
      • 181
      Unfortunately I cant post the Sample, it is a Confidential document. But it is about 1 inch wide and runs the width of the page.
      • Wild Bill
        • Jul 2005
        • 774
        Config page?
        Izzy
        • theengel
          • Nov 2011
          • 1784
          Engine test?
          • Lance15
            • Jun 2015
            • 1073
            Toner cartridge
            Secondary Transfer Roller
            Laser/Scanner
            DC Controller
            • tech28
              • Jun 2013
              • 434
              Just because the line is black, its not necessarily the black toner causing the problem, could any of the other toners. Yellow/magenta generally the culprits.
              • Blizzoo
                • Aug 2013
                • 594
                Drum ground issue.
                  do a config page... then post it
