Hp 4250 jamming when switching paper size
  • COPYDOCAZ
    • Mar 2015
    • 110
    [Jamming] Hp 4250 jamming when switching paper size
    This machine has 2 paper drawers I know the base machine is working fine I ran 200 copies in the shop, when I took it back the machine jammed when it switches from letter to legal intermittently. I tried another tray 3 assy and got the same result. the machine also has a duplex unit which seems to work great. The machine is reading the correct paper size on both trays. Very confusing.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4721
    Re: Hp 4250 jamming when switching paper size
    You didn't say if you can run 200 sheets from tray 3 without jamming. Is it only happening when switching trays?
    Look at the pad on the paper feed solenoid. Mostly every one I see now sticks because foam rubber has turned to glue.
    Also most likely nothing to do with your problem but check the exit actuator that has a pad that stick.
    I removed the sticky residue with alcohol or WD-40 then put black tape where pad was. You cannot leave bare because sol may magnetize and stick closed.
