Hewlett Packard CP5525 A3 Colour Laser Printer
  • ianstevens44
    • Feb 2010
    • 3
    Got a mega problem with above printer. Prints out first page of pantone pages fine but all other pages come out in mono but apart from the missing colour are fine. Print a demo page and get a bit of colour lead edge but then goes to mono (see example) I also uploaded a demo page of what it should look like from another printer. The colour that you get lead edge is normally cyan but is sometimes green fading to yellow. You do a config mono print, first page is ok but second page is ok until halfway across then most of print missing. Engine test page normally just shows black without colour stripes but occasionally we get about 10cms of colour stripes that fade outacross the page and over to one side. Stopped print half way through and observed image on ITB and its missing as per problem on pages. This leads me away from thinking second transfer section as well as the fact that on the second config page with print missing, the print that is there is in exactly the same place on all second pages. If it wasnt transfering properly I would expect it to be random. With this in mind I'm thinking Formater PCB or DC Control. Changed both and no difference. Have since then changed Main HVT PCB,Primary ITB HVT, Laser assembly, Low voltage PCB, Transfer roller section but not whole door assembly. ITB assembly, All drum units. I have swapped these items both ways with another printer and they have all worked fine on other machine but not improved situation on this one. I thought it looks like aproblem with ITB charge rollers that use a cam mechanism to push them in and out to give contact with the correct drum but that all looks fine. I'm now thinking it must be a drive assembly issue but that is a hell of a job to takeapart and I dont really want to remove it from their working machine incase I cock that one up to with a timing issue or something. The shutters below the drum units seem a bit wobbly but from what I can work out are moved back and forth by the drive assembly. Ive not changed the secondary transfer HVT PCB or the whole right hand door assembly but might give it a go on Monday even though it goes against my reasoning about print in exactly the same place of second config page. I read up about drum alienation but I would have thought if there was a problem in this area we would get a code. The red herring I had when I first looked at the machine was the secondary charge roller was not fitted correctly. The little white plastic retainer was bent back on itself under the roller and therefore not allowing the roller to seat properly. However by correcting this it didn't improve the problem. Ive attached four pages one of a correct demo page, one that I'm getting off this machine and first and second config page. Any help would be really appreciated.
    • 23007
    Re: Hewlett Packard CP5525 A3 Colour Laser Printer
    I believe the clue lies in the last page. When you look at the 2nd page of the config list, you can see that as the image departs you see diagonal voids, associated with loss of developing agitation.
    Were it me, I would:
    1) ... print off the attached images on your HP. Look for diagonal voids at the point of image loss.
    2) ... examine the developing agitation drive. I haven't worked on this particular HP, so that part will be up to you. I imagine you'll find a clutch or bushing or motor failure.
    Let us know what you find. =^..^=
    • theengel
      • Nov 2011
      • 1784
      I had one like this a long time ago, and I had given up on it. Later, someone showed me a few tech pubs concerning this.
      trythis.pdf
      trythis2.pdf
