LIGHT PRINTING LJ 3015
  • Techconnect
    • Jan 2018
    • 15
    Tried new print cartridge, half page test was not transfer process ...
    looking at the laser to clean the laser path but cant find it in the machine!
    The SM is not a lot of help in that area...
    very light printing of internal sheets,... printing docs seams to be a little darker..
    This machine is the fax Not the printer LJP 3015...
    • 23003
    Re: LIGHT PRINTING LJ 3015
    Have you checked the default contrast setting? See pg 26:
    The page you are looking for is no longer available or has been moved
    • Techconnect
      • Jan 2018
      • 15
      yea pretty sure.... turned every thing up I could find..
      • Iowatech
        Not a service manager
        • 3930
        If I understand correctly, the image fault only occurs with the fax function. That would indicate that the problem is primarily with the machine sending the faxes to the machine you are working on, although that machine's formatter might be causing that too.
        Grr, stupid 1980's tech. Why won't it die?
        • Techconnect
          • Jan 2018
          • 15
          no printing and internal is light copies and faxes fine
          • Techconnect
            • Jan 2018
            • 15
            PCL 6 has the Copy quality adjustments, got that loaded and helped a little, I think it was enable black in text mode the economy mode was in there
            set to off...
            ordered a print engine ...
            • linuxcoupe
              • Feb 2018
              • 6
              If I read the initial post correctly you had light print and replacing the toner has the same results. You tried a half page test and the toner was not transferring properly. If you are printing on a plain 20 lb paper I would replace the transfer roller Mfr Part #: HP RM1-6321-000CN
              • Techconnect
                • Jan 2018
                • 15
                no sir, no discernable on the pcu drum led me to eliminate the transfer process...
                • linuxcoupe
                  • Feb 2018
                  • 6
                  in that case, I have never had to get to the laser/scanner on this unit but the limited information in the service manual gives me a part number (RM1-0171-000CN) but no R&R information. From what I can tell the LS is under the cover for the output tray. Good luck
                  • Techconnect
                    • Jan 2018
                    • 15
                    thanks got the laser today,.. will try this week and update you...
                    • Techconnect
                      • Jan 2018
                      • 15
                      *** UPDATE**** My parts guy ordered the engine board and the laser and of course it was for the "P" 3015 printer
                      not the 3015 fax type of machine and I didn't realize until I had it down to the frames.... switched it out with a brother fax.. The 3015
                      its in pieces in a box on my bench...
