Lj enterprise 700 with 30.03.45 scanner error
  • axyun
    • Aug 2007
    • 1323
    LJ enterprise 700 with scanner error 30.03.45 which i understand
    may be a common problem. I read that one customer had about 8 of
    Their machines with this code. Please advise on what is usual solution
    To this issue and why this happens. Thanks for your expertise and help on this. Frank/ Action Photocopy
    Re: Lj enterprise 700 with 30.03.45 scanner error
    I've been informed the fix is to replace whole scanner section... pricey ... my customer went and bought a Brother MFP
    • Lance15
      • Jun 2015
      • 1089
      Sorry to rant on this post, but, 'Lj enterprise 700' is the SERIES......READ what is stamped on the front of the unit! I'm guessing this is an M725
      30.03.45
      Description
      Scanner control board (SCB) firmware assertion failure. SCB firmware assert controls the scan head motor.
      Recommended action
      1. Turn the product off, and then on.
      2. Upgrade the firmware.
      3. Replace the scanner control board.
      4. Replace the scanner assembly.
      Typically, the SCB is at fault from what I've seen in the past. Good luck obtaining one. I've waited two months or more for SCBs.
      • axyun
        • Aug 2007
        • 1323
        Thank you Phil + Lance. I will explain to customer and see if he wants me check out machine and that there is a good chance it will be an expensive fix. Frank
          it will be expensive ... -= IF =- you can locate the parts.
          • Lance15
            • Jun 2015
            • 1089
            Just as an example, the SCB for a Color LaserJet M680 ran me around $231. Not so bad, but, it took 3 months to get.
