hp color enterprise 500 m551
  • Users Tech
    • Nov 2013
    • 85
    Hi all,
    Problem is after printing around 700 color pages, cooling device appears and then it keeps on appearing every 20-40 color pages.
    i already replaced the fuser. printer is plugged directly to an outlet. i also unplugged the power and press the power button more than 10 seconds and turn the printer on again but it didn't solve the problem. fan is working. tried searching for the solution online but can't find any.
    hope you can help.
    Re: hp color enterprise 500 m551
    Originally posted by Users Tech
    Hi all,
    hope you can help.
    that is a LOW END UNIT... you are overworking it... split prints jobs up
    is this in an office or home?
    • Users Tech
      • Nov 2013
      • 85
      Printing shop. Any recommendation which hp model can handle this kind of print job? Client is not interested with the latest model. Any older model will do. Btw, which part of the machine is causing this "cooling device"? i already replaced the fuser but it's still coming out and the fan is working.
      Will upgrading the memory help?
      • theengel
        • Nov 2011
        • 1784
        Probably a 4700 would work. Or even a 4600. They're older, but they're pretty solid.
        • Wild Bill
          • Jul 2005
          • 774
          Internal temperature sensor, I believe it is next to the Exhaust Fan, or it is on the B/W lasers.
          Just have to wait for it to cool down apparently would be my guess.
          Izzy
            get them something that has a separate drum/toner
            it could be a number of things.. pinched wire...improper installation of fuser..... bad DCC... fan that rotates but not fast enough.... dust/dirt in fan blades.
            • theengel
              • Nov 2011
              • 1784
              get them something that has a separate drum/toner .
              HP CLJ CM6040... although those drums take a lot of money to keep up with. I wonder what printing costs are when you compare a 6040 with a 4700.
                not sure... haven't seen the 6040 in person. hopefully it isn't a SAMSUCKS engine!
                • Users Tech
                  • Nov 2013
                  • 85
                  They have 4650 and 4700 and yes they are solid but they prefer the print quality and speed of the m551 though 4700 is fast also. any comments about cp4525dn and m651dn?
                    cp4525dn = yes
                    m651dn = NO! no better than what they have now
                    • Iowatech
                      Not a service manager
                      • 3930
                      I've seen the 6040s, they're pretty solid units as long as you get decent supplies for them.
                      • fixthecopier
                        ALIEN OVERLORD
                        • 4713
                        The 4525 are pretty good machines. What is being printed? Are they using OEM toners in the 4700, because I would think the quality would be great.
                        • Users Tech
                          • Nov 2013
                          • 85
                          yup drums are expensive on this model since it's A3 size. they only need legal size max.
