HP M575dn weird connectivity problem
  • lane1957
    • Nov 2011
    • 17
    Hello everyone! I have an HP M575dn MFP that is showing a red line (band) across the network icon on the touch screen control panel. It is not an "X", but a single diagonal red line. I have not seen this occur before. The LAN port has a solid green light (link), but the yellow activity light remains dark. I have tried 2 different formatter assemblies, completely wiped the hard drive and installed new firmware from a thumb drive. Firmware loads up fine, and the MFP initializes every time. All the MFP's functions operate correctly with the exception of the network port. Same thing happens on both formatter assemblies. I print Configuration pages, and the network page never prints. It's like the MFP does not even detect the network port on the formatter board. VERY WEIRD. I have been repairing these models for quite awhile, but I have never ran into a problem like this before. Anyone have any ideas? I'm stumped on this one! Thanks!
    • 22973
    Re: HP M575dn weird connectivity problem
    Have you tried connecting your laptop to the network cable to see if it pulls an IP, and can ping other network nodes?
    Have you tried connecting your laptop to the MFP via crossover to see if you can ping, print, scan, whatever? =^..^=
    Oops, I missed this part:
    Clearly not a network issue. I have seen failed on-board network cards before, but I think you've already covered that. Have you tried initializing the NIC? Will it print the config page if it's not on the network and re-booted?
    • Laserrick
      • Oct 2014
      • 13
      Access the Preboot menu
      1. Turn the product on.
      2. The HP logo displays on the product control panel. When a "1/8" with an underscore displays
      below the HP logo, touch the logo to open the Preboot menu.
      3. Use the arrow buttons on the touchscreen to navigate the Administrator menu.
      4. Touch the OK button.
      5. Use the arrow buttons on the touchscreen to navigate the Start up Options sub menu and touch OK.
      6. Use the arrow buttons on the touchscreen to navigate the Embedded JetDirect off and uncheck.
      7. Press the back button twice
      8. Press OK when it says Continue
      • lane1957
        • Nov 2011
        • 17
        Thanks for responding blackcat. I sincerely appreciate the advice.
        • lane1957
          • Nov 2011
          • 17
          Laserrick, you were right on the money. The "Startup Option" for the JetDirect was in fact disabled. I re-enabled as you suggested and viola, problem resolved! Thank you, thank you! This one had me going. Did not think to check that area. Kudos to you and much appreciated!
