T1700--Any problems to be aware of before buying?
  • D Hook
    • Mar 2018
    • 205
    Looking at buying a T1700PS 44" and am wondering if anyone has any insight into the printer. Any reliability issues? Software issues? Will be using on Windows 10 and also a mac. Mainly for line drawings but some graphic design work also. Heavy bond and backlit materials.
    Thanks!
  • Kiran Otter
    • Dec 2013
    • 1115
    Re: T1700--Any problems to be aware of before buying?
    My only reservation with the T1700 and the other newer models that use a unified printhead, is just that; if anything goes wrong with the printhead you have to replace the entire thing and it's $600 or so. I've had a customer with one and they had to replace the print head 3 times within 2 years. Also make sure the printer is supported by your version of iOS.
    Personally I would get the T795.. though it does not have PostScript so may not be supported by the Mac.
    Kiran
    • D Hook
      • Mar 2018
      • 205
      Thanks for the info.
      As I understand it, the PS option is required to use with MAC products. The graphic designer is the only person in the building who uses a MAC so it's a requirement I'm afraid.
      Good to know about the printhead. I'll pass on the info.
      • pebkac
        • Oct 2014
        • 36
        The T795 has a raster driver for macOS, so you shouldn't need to buy the Postscript upgrade.
