HP OfficeJet Pro x476dn Jamming
  • nicktech
    • Dec 2017
    • 8
    [Jamming] HP OfficeJet Pro x476dn Jamming
    HP OfficeJet Pro X476dn, when it first starts up it will print fine, after it has warmed up it keeps jamming about a 3rd of paper is printed. can not find any solutions to this problem. any solutions will be greatly appreciated. also it will do a calibration and wont go past 4 stage and stays on 0%
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: HP OfficeJet Pro x476dn Jamming
    Jam or error code?
    Jam location?
    Pickup condition?
    • nicktech
      • Dec 2017
      • 8
      Print Zone Jam
      Paper is jammed
      Open the left door, remove the duplex unit, lower the platen
      by pressing the green latch and clear any paper. close the
      platen and insert the duplex unit.
      once done, touch ok.
        what are the conditions of the ink and printheads?
        if it's trying to run calibration and fails sounds to me like the calibration sensors are failing.
        what does it do on INTERNAL PRINTS? does it still bomb?
        how many pages printed?
        what have you done to it so far?
        Cleanings?
        • nicktech
          • Dec 2017
          • 8
          We just had to replace all colors during calibration.
          internal prints are the same as copying. it jams every time.
          we cleaned all sensors, updated and firmware.
          • nicktech
            • Dec 2017
            • 8
            it only has 18041 pages printed
              Print Zone Jam
              Paper is jammed
              ok are you finding jammed paper in the duplex? yes there in lies your problem.
              • nicktech
                • Dec 2017
                • 8
                it doesn't jam in the duplex it makes past it. If it is a sensor how would you test it? Tried sensor calibration and still doing the same thing.
                  1) get the manual
                  2) find the motor/sensor test
                  3) run it
                  • Lance15
                    • Jun 2015
                    • 1089
                    1) get the manual
                    Helpful only getting into the Engineering and Support Menus. Beyond that, your on your own. Unlike other manuals, there isn't a list of whats inside those menus and what they do.
                    • theengel
                      • Nov 2011
                      • 1784
                      The solution is easy:
                      Trash.
                      These printers aren't meant to be fixed. Don't screw with the natural order of things, man.
                      • Lance15
                        • Jun 2015
                        • 1089
                        Especially these first-gen printbar models. The newer gens are just engine swaps and move certain parts over to the new engine.
                        • nicktech
                          • Dec 2017
                          • 8
                          I agree with Theengel. I gave up on it. I have too many man hours in it. Its trashed. Thanks for all the help
