Let's play "Stump the Tech"
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Actually, I am not looking for tips, it has gone past that point. HP told me to close the ticket. I think they will replace it. Without writing a novel detailing all the little things I went through troubleshooting, here it is in a nutshell...
    HP M4555 mfp
    Issue is jamming. It only jams from tray 3,4 or 5 after the "bin full" actuator has been tripped. It will run hundreds from any of these trays as long as you keep the paper removed. As soon as the bin full actuator is tripped, then the paper removed, it will then jam on the right side every page. Tray 2 works fine. If you start a job in tray 5, trip bin full, then have it continue from tray 2, it works. I replaced the following...
    Entire tray 3, 4 and 5 cabinet
    output unit
    fuser
    formatter/hdd
    DC controller
    I called it dead at the end of day and closed my ticket. This has drug on as a third party ticket for over 2 months now. Glad to see it go, but still want to know what the hell is going on.
  • copier tech
    • 8156
    Re: Let's play "Stump the Tech"
    Sounds like a firmware bug, I guess you would have updated that before changing boards?
      HP M4555 mfp
      output unit
      fuser
      formatter/hdd
      DC controller
      Brother.. 'bout the only thing besides new firmware wuold have been a total mem clear back to factory defaults before the firmware.. other than that I think you did everything expected.. AND if HP said to "drop it" .... RUN FOREST RUN!
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        oh yes, several times.
        • ofcourse
          • Jul 2017
          • 6
          Do you remember what the official jam code was?
          I'm assuming that your specific jam code referenced a jam at the output area, but double-check that code because sometimes paper that appears to stop at the tail of the print process only jams because there is a timing error with a secondary/trailing page earlier in the printer path.
          If you're looking for other random possibilities ... the fuser drive assembly is very prone to wear on this model (similar to M601/M602/M603 and will usually make a deep, heavy humming/grinding noise as it starts to wear) and gummy/sticking solenoids for paper pickup can cause some weird timing issues, although replacing that lower cabinet should take care of the pickup solenoids for trays assuming the second cabinet didn't also have gummy solenoids.
          Duplexer might also be a consideration for slowing down timing / triggering jams, if that's being used on these jobs.
          Paper size settings might also be a consideration if those for the lower trays didn't match the upper Tray 2.
