Error Code 55-203 on a Contex GF67D 40"
+ More Options
Posts
  • pbrooks259
    • Jun 2017
    • 162
  • Kiran Otter
    • Dec 2013
    • 1109
    Re: Error Code 55-203 on a Contex GF67D 40"
    There's so many models, however; it might be something as simple as a broken 'belt' on the camera mechanism. It's actually just an o-ring they use to go from the motor to the wheel that adjust the camera.
    You can buy it at a hardware store usually. If you need the size I can measure one.
    I think in new models they did away with the belt and went direct with the motor. But if it's like the cc800ps or 815mfp.. it's a o-ring.
    Kiran
    • pbrooks259
      • Jun 2017
      • 162
      Thanks, Kiran. I will look into it or pass that along.
      Paul
      • pbrooks259
        • Jun 2017
        • 162
        furthermore, do you know how to "erase parameter blocks" on an HP Designjet Scanner 4200? I know on a 4500 scanner that in scanner maintenance you select it from a drop down menu, but I don't know how to "erase parameter blocks" on a 4200. Maybe I am missing something in "scanner maintenance".
        Thanks.
        Paul
        • Kiran Otter
          • Dec 2013
          • 1109
          I've never had the need to 'erase parameter blocks' but I would assume it's the same process; from the scanner maintenance program.
          Kiran
          • D Hook
            • Mar 2018
            • 205
            Just a test post.
