hp m651 error 46.23.07
  • armin2570
    • Jun 2015
    • 44
    [Error Code] hp m651 error 46.23.07
    hi
    i have a hp-m651 show this error 46.23.07 and no work printer.
    i do upgrade firmware but again show this error
    i cannot find this error at service manual
    i do it is urgent
    thanks alot
  • Lance15
    • Jun 2015
    • 1088
    Re: hp m651 error 46.23.07
    46.* error messages Errors in the 46.* family occur when the printer is trying to perform an action that it is not able to complete.
    • No network connectivity
    • A problem with the file being printed, with the software application sending the job, or with the print driver
    Recommended action Use the following general troubleshooting steps to try to resolve the problem. If the error persists, elevate the case using the Standard Support Process.
    1. Turn the printer off, and then on.
    2. Verify the printer is connected to the network. If it is not, use a different network cable, and check the configuration settings.
    3. Send a different file from the same software application to see if the error is specific to the original file. Try sending a job from a different software application to see if the error is specific to the application. Verify the computer has the correct print driver installed.
    4. Upgrade the printer firmware.
    5. If the error persists, use the troubleshooting flowcharts in this document: HP LaserJet FutureSmart Devices - 49 error Troubleshooting (Persistent and Intermittent)
    • theengel
      • Nov 2011
      • 1784
      1. Unplug the network cable and see if the printer will come to ready.
      2. Then print self-generated reports, and see if those print.
      3. Then change the IP address, so that you know nothing is trying to send a job, and plug the network cable back in.
      If you cannot get it to "ready" then you need a formatter.
      If you get it to ready, and then get the error when you plug in the network, AFTER you've changed the IP address, then you need a formatter.
      If don't, and then you change the IP address back, and you get the error, someone has a corrupt job that they keep trying to send. Empty everyone's queue.
