Has plenty of ink , black is new , has light print quality for all colors . Ran demo pages and supply pages , all colors light , ran through a 2nd side to check for moisture in paper , still the same . Pulled print cartridge drawer out and wiped down ITB , ITB looked great . Checked rear and inspected the transfer roller , looked good . Run color calibration now , still the same after . Machine only has 6,228 pages on it . No other issues noted at this time . I suspect high voltage power supply , but likely not worth fixing if it is this . Anyone seen this and resolved ? Thanks in advance , Ark . Sorry about redundant posts , no way to delete ones that are broken .
CM 1312nfi MFP Light pages output
Re: CM 1312nfi MFP Light pages output
Check the quality of the image on itb. You will find out whether the problem is with the transfer to the paper or before it like a laser etc ..Last edited by zoraldinho; 12-06-2018, 10:54 AM.Practice makes perfect
If you want something done right, you have to do it yourself
