hp LASER JET 600 m601 i cant get to "reports" from the display panel
  • tonerjockey
    • Apr 2014
    • 571
    Hi guys, Happy Valentines Day.
    i am really missing the ball on this one. i spent some time trying to get to the reports, or admin so i can get the serial number, engine counts, usage page, error codes or jam codes etc.
    even when I installed it for them some time back, the display apparently needs a service password, or user or other access code to get in. basically, all I can do is open the help screen that gives useless info for me.
    does anyone know what is needed to get into the display options?
    I would really appreciate any advice given.
    thank you, Jim
    Re: hp LASER JET 600 m601 i cant get to "reports" from the display panel
    Originally posted by tonerjockey
    Hi guys,
    I would really appreciate any advice given. thank you, Jim
    Jim.. I believe ADMIN>reports and from there your on your own
    • tonerjockey
      • Apr 2014
      • 571
      but i cant get to anything. all others, i go that route.
      all i see is places to enter access codes.
      i am going back for another printer there tomorrow. i will look again and take a picture of the display and choices.
      thank you very much, and i will reply to this link tomorrow. have a very nice evening, Jim
        Hmm someone set up codes... in admin.. user admin password < blank>
        • theengel
          • Nov 2011
          • 1784
          Re: hp LASER JET 600 m601 i cant get to &quot;reports&quot; from the display panel
          I think when someone sets a password, it is done from the webadmin menu--you have to do it from a computer when it is online. I'm not sure if there's a way around this. Maybe you can do a reset, and then get into it.
          • Lance15
            • Jun 2015
            • 1089
            I think you can change those codes in the pre-boot menu. I THINK. I think I did it once due to being locked out of a service area I needed to get into.
            • tonerjockey
              • Apr 2014
              • 571
              Whats werad, the customer presented this printer several months ago to have me install it. obviously everything is on a server. but even on the first boot up, i dont think i was ever able to see the normal screen.
              i tried everything. the only thing i could print was a help page. which caught me off guard, as i wasn't able to set any printer info data.
              so, now i was there for a service issue, and still i have no way to get page a page count. and none of the other printers act this way.
              I see i wrote the wrong model number. its a M607. Sorry.
              i am going back today and will get better info. Happy Friday, Jim
              • Lance15
                • Jun 2015
                • 1089
                I'd just format the disk and start from scratch. Make sure you have the firmware on a FAT32 formatted stick as that's the only way to reinstall the firmware. Give yourself at least 20 minutes. It will copy the firmware into the repository, then, it will copy that "gold firmware" into the active partition and install it.
                • tonerjockey
                  • Apr 2014
                  • 571
                  Happy Friday guys.
                  ok, i got there and at first it seemed futile, as i have been there before trying for a while and never any luck.
                  Well, somehow all of a sudden there was icons for supplies, reports on and on etc. then in a kookie way, i figured out how to navigate the screen that looks like a touch screen, but isn't and got the config and usage pages.
                  whats odd, i had all the literature that came with the printer, and i don't recall anything about the screen. i guess HP.com is where they furnish the info to use it. not with the blue tape you peel off, so you can peel out of the parking lot after you set it up.
                  i retraced my steps, and from the home screen, if you call it that, which has two icons, called "job storage" and USB Drive" above that is "Reset" and Sign In"
                  well, if you hit the right arrow key, then you see additional icons that allow you to navigate as with prior HP laser jets, but different enough for me, it wasn't intuitive, at least for an old school tech like apparently ME. i must have hit every conceivable possibility, with the exception of the correct one.
                  so, i feel kinda stupid, but hey, its Friday, and i got the info i needed finally.
                  thank you for giving me the needed push to getter done.
                  Have a great weekend, Jim.
                  • Lance15
                    • Jun 2015
                    • 1089
                    Yeah. Understandable.
                    I was under the impression the control panel was locked out, but, I can understand the frustration on these non-touch panels using the FutureSmart 4 firmware which is more intuitive WITH a touch panel than using physical buttons.
                    The first one of these I came up on, I was just as confused as I fumbled around trying to touch the non-touch screen, then, pushing the buttons and paying attention to the dotted outline that appeared around the icons and other buttons. Hard to see unless you are looking for it! Stupid on HP's decision.
                    • tonerjockey
                      • Apr 2014
                      • 571
                      totally, to select things, you have to get down to the bottom and move right to the select. hitting ok, repeatedly, don't help. and me too, i kept trying to press the LCD.
                      the old big blue button method worked fine. guess they want to make their products compete with brother? gotta give them a screen. that's better right??
                      Have a nice weekend, Jim
                      • Tom
                        • 344
                        Personally I'm not a fan of those Mi607's at all. To make a cheaper printer, they beefed up the design of the lower end models instead of sticking with the same engineering concept they've had for the post 20 years on their heavy duty printers from the 4000 on up. I love the 4015's and M600 series printers, but these new ones coming off the line are decieving, cause they make the customer think they're getting a good deal when they're not. Lower PM counts but the kits are more expensive, how is that going to save any money over the long run. I just don't think they're going to hold up as well and have no plans on selling any myself, but I have a customer that went online and upgraded their whole fleet to them with asking my advice first. Argh. Maybe I'll just sell them toner only.
                        • tonerjockey
                          • Apr 2014
                          • 571
                          i totally agree. the customer never looks at the maintenance interval, just tells you that your price is to high and they are going to just get this thing. HP wins again in selling more flimsy machines. but hey, sell them service and supplies. but unfortunately, these will also be compartmental replacement "modules", and that pretty much closes us out of the deal.
