weird toner question repeating defect
  • printlessguy
    • Sep 2015
    • 63
    ok I know it is a bad cartridge. but the problem still doesnt make sense.
    HP P4015n printer. compatible cartridge 364x. getting a whitish void right to left 1 per page on letter on legal is 2 voids. the spacing is 190mm. nothing in the cartridge has that circumference. the drum is 95ish mm. so that sort of makes sense except for the every other rotation aspect. just tryign to figure it out. already swapped the cartridge and life is good, but curious.
    thanks
  • allan
    RTFM!!
    • 5462
    Re: weird toner question repeating defect
    Does the voids move or stay in the same location?
    Could be a bad HV connection.
    Whatever
    • printlessguy
      • Sep 2015
      • 63
      Seem to be always within an inch of each other page to page. Hv on catridge? Problem is distinctive to only this cartridge
        • 23007
        This sort of thing can be confusing. The key here is that the developing roller does not turn at the same speed as the drum ... it turn much more slowly.
        If you were to do an autopsy on the cartridge I think that you would find mottling on the developing roller.
        • printlessguy
          • Sep 2015
          • 63
          hmm thanks cat I may perform surgery tomorrow
