hp 4050
  • jlvelez
    • Nov 2008
    • 25
    hp 4050
    I have just install a pm kit on this hp 4050 and i can't rest it can anyone help me
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Turn printer off
    Hold down [-item ] and [ -value ] while turning printer on
    "reset maintenance count" appears followed by "initializing" followed by "ready"
    • jlvelez
      • Nov 2008
      • 25
      hp 4050
      I did all that but all the printer tells me is count....initia....and ready that's all
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        That is what it is supposed to tell you. That is the reset.
        • prntrfxr
          • 1622
          hp 4050
          Follow steps Fixthecopier gave you, then print a configuration page. (Press MENU until "INFORMATION MENU" appears, then press ITEM until PRINT CONFIGURATION appears, and finally press SELECT to print a configuration page). On the top left it should say: "Pages Since Last Maintenance = ####". The number of pages should be low if you've reset it. The maintenance message would also go away after you performed the reset.
          In case you prefer Spanish:
          Siga los pasos que dice Fixthecopier, pues imprime una pagina de configuracion. (Empuje Menu hasta vea "INFORMATION MENU", entonces empuje Item hasta demuestra PRINT CONFIGURATION, y finalmente empuje Select para imprime pagina de configuracion). En la izquierda dice "Pages Since Last Maintenance = ". La cuantidad de los paginas va ser muy poco si hace correcto. Espero que esta infomacion le ayuda.
          Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
          • jlvelez
            • Nov 2008
            • 25
            hp 4050
            You got to excuse me but i was out of town and i was not abel to reply to your tread, but yes i got it fix and tks a lot to all off you .
