HP M477fdn intermittent 59.F0 code
  • copytech,mike
    CopyTech,MIKE
    • Jun 2014
    • 261
    Re: HP M477fdn intermittent 59.F0 code
    Originally posted by Lance15
    This belt is tricky. The part that got me on my first one were the "levers" above the power supply. Did you put those back in the correct positions? You re-connected the two rear connectors?
    I've replaced 3 or 4 of these on the single-function (M452) under warranty.
    The levers pull down, then, pull slightly out when removing, then push slightly back in and back up when reinstalling. I was afraid I was going to break them as much force as you need to exert to unclip and clip them. Secondary transfer assembly flush?
    A flush? Throw that piece of junk in the dumpster and tell your customer to buy a new printer.
    • tsbservice
      Field tech
      • 8018
      Duhh. Why not. Barking on the wrong thread again
        Him being a salesman uses that line often.
        We have another sales guy here, they both parrot that same line.
        What they fail to realize is not everyone has the cash to be able to do that, hence the reason for repair techs.
        • mandongo
          • Mar 2021
          • 32
          #19
          Is it possible a sticky solenoid to be the reason for 59.F0 in this case? I have replaced solenoids in other models HP printers after 59.F0 error.
            There is a solenoid inside the transfer belt that raises / lowers the color transfer belt brushes (think of internal transfer rollers).
            If this was sticking, I doubt a firmware patch would fix it, but then when a five-minute software update fixes this, is it really worth going any further.
            • rapo_tech
              • Feb 2019
              • 114
              #21
              It is not a solenoid problem.
              There is a little microswitch in transfer belt. Voltage that goes through the switch is so low that if microswitch gets a lil dirty or is worn, it will trigger 59.f0 error.
              The software update raises the voltage that goes through microswitch - most of time this helps.
              You can also clean the switch, but i recommend software update.
              HP M377dw — error 59.F0 Ошибка Выкл. и Вкл. устр-во - YouTube
              • mandongo
                • Mar 2021
                • 32
                #22
                I just found a solution:
                It worked for me.
                Hope it will help you.
                • copytech,mike
                  CopyTech,MIKE
                  • Jun 2014
                  • 261
                  #23
                  Originally posted by daprex
                  Hi sorry for waking up an old thread, har anyone tried using this file on a machine with a different serialnumber series ? It mentions that its only for specific serialnumbers on the attached webpage, but does not mention that in installation instructions.
                  // J
                  The solenoid is sticking. Foam pad wears out leaving sticky glue. Solenoid is what engages the trans belt.
                  • copytech,mike
                    CopyTech,MIKE
                    • Jun 2014
                    • 261
                    #24
                    Its a sticky solenoid that has a foam pad that turns sticky. Clean her up real nice with solvent and dont put any tape or pad on it. The solenoid is what engages the transfer belt.
