Anyone successfully clone a Designjet hard drive?
Designjet t2500 hard drive
Need help with HP Designjet T2500 Postscript eMFP Product No. CR359A, does anyone have image for the hard drive (CR357-67083) it is Rev. A. 320 gbAnyone know how to create a Virgin Hard Drive with firmware on it?Thanks.Comment
Re: Designjet t2500 hard drive
HP Designjet T1500, T2500 New 500gb Hard Disk Drive HDD L2Y23-67005, L
Maybe someone else will have a way to set up one by hand.
KiranComment
Re: Anyone successfully clone a Designjet hard drive?
Thanks Kiran,
i searched in the old stuff for an ide hdd but they were all broken, but i remembered i had compact flash to ide adapters with 8gb cards, i uploaded the image and it worked.
I hope this can be useful to know.Last edited by Massimo Italy; 06-08-2023, 01:23 PM.Comment
I will throw in my $ 0.02 to this. I will be attempting to clone a working Designjet 4000, 40GB drive that has only 8GB left... No jobs stored whatsoever. I have a spare HDD and an SSD. The firmware version is 5.5 and honestly I might upgrade it via EWS once. I read somewhere that the formatter board doesn't have a controller for SSDs installed in any HP Designjets... A Russian guy on YouTube proved me wrong. I will attempt both and will share my results here. I'm quite happy to get the nozzles in majority back to operating condition. Machine sat for around 5 years from what I seen on the error logs and the dust cover.Comment
New to the party, but I have a lot of experience with hard drive cloning and whatnot so I'll share what I know.
First, If it's an IDE drive and you want to replace it with a compact flash card, that should be a very easy fix since CF cards are native IDE. You simply need an adapter like this one from startech that doesn't do any type of translation or funny stuff:
IDE 40 Pin to Compact Flash SSD Adapter - Drive Adapters and Drive Converters | Hard Drive Accessories | StarTech.com
40/44 Pin IDE to CF SSD Adapter - Drive Adapters and Drive Converters | Hard Drive Accessories | StarTech.com
3.5in Drive Bay IDE to CF Adapter Card - Internal Card Readers | Hard Drive Accessories | StarTech.com
Note the connector that goes into the drive interface/cable. Depending on the situation and space, you may want to use the bay version to mount it like the hard drive was. These adapters should be completely transparent to the machine and appear as a genuine IDE drive. (They're also used often for retro/vintage computers to replace those hard drives too.)
Second, let's talk about cloning. If you have an existing drive and want to clone it fast and dead simple on the spot when you suspect it's just a bad drive, a cloning dock does the job fast and easy. I have this one by Startech, but they make newer ones too:
Dual Bay SATA Hard Drive Duplicator - HDD Duplicators - Hard Drive Cloning/Copying | StarTech.com
Newer ones:
SATA HDD Duplicator Dock - eSATA USB - HDD Duplicators - Hard Drive Cloning/Copying | StarTech.com
Standalone Hard Drive Duplicator, Dual Bay HDD/SSD Cloner/Copier, USB 3.1 (10Gbps) to SATA III HDD/SDual Bay Hard Drive Duplicator 2.5/3.5" SATA HDD/SSD Cloner
This one would be the ultimate if you run into a lot of IDE drives, but it's now discontinued and expensive even used:
But startech as these adapters for their sata docks for IDE drives:
https://www.bhphotovideo.com/c/produ...5_ide_hdd.html
If you want to go the computer route for cloning, there's only one thing I recommend--Clonezilla Live CD. It's a simple booting CD that will allow you to clone any drive to a drive, or a drive to an image, or an image to a drive (including USB drives so you can use your dock that way to write an image if you want). I've been using this for years. You can even use it over a network drive, like to a NAS. So you can easily clone or restore images to a drive from a central repository if you have one.
Of all these options, I prefer the cloning dock because it is the most accurate by far since it doesn't attempt to access the source drive in any way except to read its sectors. Clonezilla attempts to do the same thing, but hardware implementations are usually better (and faster) than software hence my preference for the dock. Plus, with a dock you can literally do it on the spot--and fast!
Also, I need to mention the importance of quality. Notice I recommended only Startech branded products even though there's probably 100x clones out there? These a simple reason why I did--quality. You won't have a problem down the line because an IDE CF adapter stopped working or a drive clone wasn't done right. It. Just. Works. I think almost everything I have from startech is still working 10yrs+ later.
Hope this helps! Feel free to ask questions!Comment
Hi - i have managed to copy the hdd for a z5600 that's new. - there's lots of partitions named ex3- 1-3 - ect..
in the folder i found PUMA_01_03_00.1.unsigned.fmw.sig - - this is the signature file .
is this possibly be the first firmware this machine was shipped with
if anyone want me to find certain files or folders on the hdd -Comment
just found a whole html file with the system error codes
#0x20107006 LOPES_EH_BSL_FILL_CHAR_BLOCK_TIMEOUT Internal Software error. 79:04 Assertion Update system software (firmware). STRING_POWER_OFF Comment
System Errors - Index by Customer Code0x10504001 DRACO_DATA_MNGMT_NVM_MAIN_CRASH Main NVM failure: not detected, read/write failed or readback error. 06:10 Hard disk Replace. STRING_POWER_OFF Comment
Sure will do, i have not tested it yet i didn't plug the machine in.
The machine is now put away in stock -
the hdd copy is done on acronis true image.
for other machines i think they need a certain boot partition then have the firmware on the usb to do a firmware update or see if the eeprom reset can be done.Comment
hi update i have manage to get a hold of the PUMA_01_03_00.1.fmw file.
if anyone want it to try and install the firmware.
hdd partition list
1st 244.1mb
2nd 11.4gb
3rd 11.4gb
4th 1.9gb
5th 19.1gb
6th 38.1gb
7th 85.8gb
8th 47.7gb
9th 47.7gb
10th 33.4gb
hdd model
ST500LT012-1DG142
500GB SEAGATEComment
