Re: Anyone successfully clone a Designjet hard drive?
Hello! Sorry for reviving an old thread but i have a Designjet T975 with a hard drive making sounds and giving me 08.11 error. Does anyone have an image for this?
Edit: After hooking up the drive to a pc for cloning attempts its asking for a password as you guys have mentioned already, but where can i find one for that model?
Originally posted by Agouri
Had a HDD failure on a T770 today. Looking for an image to burn on a new disk if anyone has it,
otherwise I'll begin attempting an 1:1 sector clone using an ICY BOX.
Thank god this forum exists by the way
Please I need an image for it as well, did you manage to find one?
Originally posted by wav
hi there the name model- yes its a direct copy of the new hdd .
pm me.
its a large file.
I tried to write to you privately but it gives me this error... "wav has exceeded their stored private messages quota and cannot accept further messages until they clear some space."
Hi All
This is a very informative thread. Than you for keeping these old horses alive. I have a designjet 1055cm plus I am trying to resurrect. I replaced the drive years ago and forgot how I did it. The drive appears to be working but I wanted to clone it just in case of failure. It has been about 8 years. I am having trouble trying to burn an image but am still trying. Does anyone have any tips for cloning? I am using an ide to usb adapter in clonezilla but I am having issues with copying an image of to a file. I only have 1 ide adapter so I can't try disk to disk. Even better, would someone have an image from a 1050 / 1055 hard drive? Any help would be greatly appreciated. Keep up the good work.
Originally posted by Thekidz
Hi All
Thanx
Craig
It is a very old method but if you can get a utility that can do absolute sector copying it is possible. I used to use Norton Utilities under DOS.
Hi and thanx. I don't have a pc old enough to have an ide interface. I don't think dos had usb drivers back then. I have a second usb adapter coming to try direct disk to disk with clonezilla. I may try searching out an old pc. Thanx for the suggestion. I will keep trying.
Originally posted by Mike95
Hi Kiran,
I have also been searching for that disk image. Could you please PM me that info too?
-Mike
clear
auto_awesomeDesculpe ressuscitar
160 / 5.000
Sorry to revive the topic, but I need an image of the HD of an HP Designjet T2300, could anyone make this image available or indicate where I can find it?
Sure will do, i have not tested it yet i didn't plug the machine in.
The machine is now put away in stock -
the hdd copy is done on acronis true image.
for other machines i think they need a certain boot partition then have the firmware on the usb to do a firmware update or see if the eeprom reset can be done.
Any chance I would be able to get a copy of that image? I recently bought a Z5600 from a recycler but of course they pulled the drive for data security. I have a ton of hard drives but I need the special HP Blessings to give it life again it seems.
I have T610 image, I successfully saved/cloned from a jammed head HDD.
I am looking for T790 image, if any one can help highly appreciate!
Thanks,
L
Hi there! I have a working T790, but how to make an image from HDD?...the HDD is password protected. , when I plug the HDD in PC it asks for the password and I don't know it...
Any hints?
