Anyone successfully clone a Designjet hard drive?
  • wav
    • Oct 2021
    • 283
    #61
    Re: Anyone successfully clone a Designjet hard drive?
    update - i have now got a clone for a hp DesignJet t930/t1530- new hdd p/n L2Y21-67004
    • eberak
      • Nov 2023
      • 2
      #62
      Hello! Sorry for reviving an old thread but i have a Designjet T975 with a hard drive making sounds and giving me 08.11 error. Does anyone have an image for this?
      Edit: After hooking up the drive to a pc for cloning attempts its asking for a password as you guys have mentioned already, but where can i find one for that model?
      • wav
        • Oct 2021
        • 283
        #63
        hi -
        can any one help with a hdd clone of a t1700
        • erquaglia
          • Nov 2023
          • 1
          #64
          Originally posted by Agouri
          Had a HDD failure on a T770 today. Looking for an image to burn on a new disk if anyone has it,
          otherwise I'll begin attempting an 1:1 sector clone using an ICY BOX.
          Thank god this forum exists by the way
          Please I need an image for it as well, did you manage to find one?
          otherwise does anyone else got one?
          thank you so much guys
          • DPSolutions
            • May 2015
            • 20
            #65
            Originally posted by wav
            Hi, do you also have a clone for hp DesignJet T930 p\n: L2Y22-67004?
            • wav
              • Oct 2021
              • 283
              #66
              hi there the name model- yes its a direct copy of the new hdd .
              pm me.
              its a large file.
              • DPSolutions
                • May 2015
                • 20
                #67
                pm me.
                its a large file.
                I tried to write to you privately but it gives me this error...
                "wav has exceeded their stored private messages quota and cannot accept further messages until they clear some space."
                • Thekidz
                  • Feb 2024
                  • 2
                  #68
                  Hi All
                  This is a very informative thread. Than you for keeping these old horses alive. I have a designjet 1055cm plus I am trying to resurrect. I replaced the drive years ago and forgot how I did it. The drive appears to be working but I wanted to clone it just in case of failure. It has been about 8 years. I am having trouble trying to burn an image but am still trying. Does anyone have any tips for cloning? I am using an ide to usb adapter in clonezilla but I am having issues with copying an image of to a file. I only have 1 ide adapter so I can't try disk to disk. Even better, would someone have an image from a 1050 / 1055 hard drive? Any help would be greatly appreciated. Keep up the good work.
                  Thanx
                  Craig
                    • 37072
                    #69
                    Originally posted by Thekidz
                    Hi All
                    Thanx
                    Craig
                    It is a very old method but if you can get a utility that can do absolute sector copying it is possible. I used to use Norton Utilities under DOS.
                    • Thekidz
                      • Feb 2024
                      • 2
                      #70
                      Hi and thanx. I don't have a pc old enough to have an ide interface. I don't think dos had usb drivers back then. I have a second usb adapter coming to try direct disk to disk with clonezilla. I may try searching out an old pc. Thanx for the suggestion. I will keep trying.
                      • Libus
                        • Jul 2023
                        • 1
                        #71
                        I have T610 image, I successfully saved/cloned from a jammed head HDD.
                        I am looking for T790 image, if any one can help highly appreciate!
                        Thanks,
                        L
                        • Lasek
                          • Dec 2022
                          • 1
                          #72
                          Hi
                          Has anyone managed to get a working image of the HP DesignJet T770 HDD?
                          • vinigrande
                            • Mar 2024
                            • 2
                            #73
                            Originally posted by Mike95
                            Hi Kiran,
                            I have also been searching for that disk image. Could you please PM me that info too?
                            -Mike
                            clear
                            auto_awesomeDesculpe ressuscitar
                            160 / 5.000
                            Sorry to revive the topic, but I need an image of the HD of an HP Designjet T2300, could anyone make this image available or indicate where I can find it?
                            • burritovampire
                              • May 2024
                              • 1
                              #74
                              Sure will do, i have not tested it yet i didn't plug the machine in.
                              The machine is now put away in stock -
                              the hdd copy is done on acronis true image.
                              for other machines i think they need a certain boot partition then have the firmware on the usb to do a firmware update or see if the eeprom reset can be done.
                              Any chance I would be able to get a copy of that image? I recently bought a Z5600 from a recycler but of course they pulled the drive for data security. I have a ton of hard drives but I need the special HP Blessings to give it life again it seems.
                              • razvy79rzv
                                • Feb 2022
                                • 3
                                #75
                                Thanks,
                                L
                                Hi there! I have a working T790, but how to make an image from HDD?...the HDD is password protected. , when I plug the HDD in PC it asks for the password and I don't know it...
                                Any hints?
