HP laserjet 500-M551 very faint image after replacing main drive unit.
  • Hansen88
    • 1068
    Replaced drive unit because of a noise issue. Now copies come out very faint,what image there is is mainly along the rear side,uneven. I have taken everything apart many times to try to see anything out of place from when the drive was replaced. The drive was timed properly as per the manual. Kind of at a loss at this point. Any help would be appreciated. I dont work on printers much so not real familiar with this machine.
  • 1stcavvet
    • Apr 2015
    • 231
    Re: HP laserjet 500-M551 very faint image after replacing main drive unit.
    sounds like a grounding issue, make sure the transfer roller is in properly. should be grounding on one end spring ---copper piece something. Stop the page half way check the toner cartridge if it prints good there it's the transfer. if not you lost a ground somewhere doing the drive unit GOOD LUCK
      Did you have to remove the the HVPS(s) boards? Contacts not set right?
      Did you clean all the laser slits glass and even the laser mirrors/glass? And time I'm In that far on ANY unit I always do the above.
      Do you have a manual? PM me.
      • Lance15
        • Jun 2015
        • 1088
        +1 for Phil's first point
        Make sure the HV boards contacts line up with the springs.
        • Hansen88
          • 1068
          Thanks for the replies. It makes sense it has to be something from when being taken apart. I have taken it back apart a few more times looking for what may have happened. All the spring contacts look good-touching. Here is some sample prints. What is on the page looks good. Almost looks like transfer problem.
          • Copeya
            • Mar 2018
            • 26
            I would definitely say that's transfer related.
            • Lance15
              • Jun 2015
              • 1088
              Maybe these document will help?
              Missing or Light Color Planes on Printouts.pdf
              Troubleshooting Tools (PQ Issues, Noises, Engine Diags).pdf
              Also, make 100% sure a connector didn't hide behind the DC Controller when you were putting things back together.
              • Hansen88
                • 1068
                Well we fixed the customer but not the printer. We got another printer for parts and changed all the parts that had anything to do with changing the drive unit and still no luck. So we put the second machine back together,cleaned it up ect and brought that one back to the customer.
