HP CM 4540
  • 1stcavvet
    • Apr 2015
    • 232
    [CQ] HP CM 4540
    I install a whole scanner unit on this machine ---Prints (supplies status page) from inside the machine were perfect and the copies(of those same pages) where all washed out. sorta overall washed out ---no voids.
    still have the same problem Open for ideas formatter would be my next try-- the formatter is where the image goes after the scanner see's it and before it prints ---- like I said any ideas would be appreciated THANKS
  • 1stcavvet
    • Apr 2015
    • 232
    Re: HP CM 4540
    I'm going back to the customer Monday to check the connections on the interconnect pcb and the DC controller, any other suggestions??? Thanks
      • 22784
      Re: HP CM 4540
      did you run calibrations on the new scanner once installed?
      • 1stcavvet
        • Apr 2015
        • 232
        Re: HP CM 4540
        Yes I did, The scanner calibrations, are more for alignment than color so I reran the color calibrations also, both from the adf and the glass. Like I said the machine does prints from the computer and the menus great just the copies, of the just made prints, copy washed out looking
        • 20 year tech
          • May 2014
          • 575
          Re: HP CM 4540
          definitely recheck those connections. curious why you replaced the scanner in the first place.
          • 1stcavvet
            • Apr 2015
            • 232
            Re: HP CM 4540
            The prints looked perfect and copies of those same prints are washed out All the colors and black like your looking at the page through a fog
