LASERJET M570 Top Bin Full Error
  • Assaf
    • Jun 2009
    • 59
    The machines keeps indicating the top cover is full but there is no paper. I assume is the sensor, Anyone experienced this before?
  • Copeya
    • Mar 2018
    • 26
    Re: LASERJET M570 Top Bin Full Error
    Have you checked the output bin sensor and actuator?
      those sensors can get whacked when people remove paper improperly from the bin
      • kashif
        • Apr 2013
        • 45
        You should first clean the sensor and i hope after clean sensor message will not come.
        • Assaf
          • Jun 2009
          • 59
          Thank you guys for the help, I did clean the sensor but no luck. I been looking for the sensor part number online and i cannot find it.
            • 22999
            If this is the same finisher as the M880 then yes, I've seem that. Changing sensor board did not help. I ended up changing the entire elevator tray assy on two of those finishers. =^..^=
            EDIT: the M570 is a totally different animal. No finisher available.
