HP M72630dn is it copier or laser printer?
  • windcopier
    • Apr 2019
    • 51
    Hi.
    Im new guy in here.
    Just like to ask that is it HPM72630dn is a copier or laser printer?
    Looks like a copier but it does not state that is a copier machine.
    is it because the monthly volume capacity?
    Any review can be share? Pro or Con?
    thank you
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: HP M72630dn is it copier or laser printer?
    It's laser MFP. Copy-scan-print.
    • windcopier
      • Apr 2019
      • 51
      Thanks.
      May i know how much 1 month can be print or copy how many paper volume? 10,000 pages?
      • zoraldinho
        • Mar 2008
        • 5007
        Originally posted by windcopier
        Thanks.
        You are not realy familiar with Google or is it just laziness?
        Duty cycle (monthly) Up to 80,000 pages (per month); Recommended monthly page volume: Up to 40,000 pages (per month)
        Datasheet link
        • windcopier
          • Apr 2019
          • 51
          Datasheet link
          Haha ... is hard to believe want does hp describe on it. Up to 40000 pages. That is mid heavy volume copier machine like MP4054 or MP6054.
          But thanks for the info.
            Haha ... is hard to believe want does hp describe on it. Up to 40000 pages. That is mid heavy volume copier machine like MP4054 or MP6054. But thanks for the info.
            well MOST copiers are built off of a laser engine...
            for the longest while, to get PRINT/FAX in a copier..it was an added cost and labor time.
            the MFC (brother) or MFP (hp) have all the option IN it from factory (as a fully loaded unit)..so no need to buy the options
            down side.. certain models have the AIO toner/dev units...
            40,000pgs is based on: LTR paper...approx. 5% coverage on the page (logo's - borders ..any fancy fonts ect will eat the 5% up)
            • windcopier
              • Apr 2019
              • 51
              Agree what you said. Thanks for the info.
              Is true that. Ricoh Canon KM and Xerox require buy for the optional feature.
                Not every model of those brands..
                Higher end units in each class more times than not are fully optioned out
                • windcopier
                  • Apr 2019
                  • 51
                  the only im not sure that is it this hp model really can act same like copier because the price is far more cheaper then mid heavy volume copier and some more the maintainance.
                    Keep in mind the $$ for the aioli cart...
                      • 23007
                      Please keep in mind that dealer specifications are always optimistic in the extreme. If you were to run 40K per month you would destroy it in less than a year.
                      A more realistic estimate is to take the dealer number: 40K and divide it by 1/2
                      20K is a more realistic number. =^..^=
                      • windcopier
                        • Apr 2019
                        • 51
                        Thanks for your suggestion.
                        Yes. you are right. most possible that the volume is only 15-20k (i dont think can be last for 20k within 5 years) per month and the costing of the maintain for consumable part are more expensive because look at the manual of the spare part design. Example Heating Unit (own opinion).
                        • zoraldinho
                          • Mar 2008
                          • 5007
                          Like Kyocera printers for 200$. Drum and developer life 600K?
                          • xring1958
                            • 166
                            HP sold a rebadged version of a Sharp MFP retativly recently. This may be a rebadged version of another brand since it doesnt resemble the current sharp equipment. When I was a field tech I hated the short lived rebadged equipment because they often were not serviced well by the adoptive company since the operating systems like sims and codes varied from the normal equipment that the company serviced. When the customer finds out it is really brand Y not brand X and comes to Brand Y for proper service the machines might have changes that make servicing or suppling them difficult.
                            • windcopier
                              • Apr 2019
                              • 51
                              Wow....
