HP CM3530 error 49.1805
  • c3110
    • Jun 2019
    • 16
    [Error Code] HP CM3530 error 49.1805
    Hi,
    I have a customer with an HP CM3530 MFP wich started throwing this Error 49.1805 code usually when trying to print after the MFP went to sleep\stand by. It sometimes reboots by itself even though the error text says to manually reboot the machine.
    I'm attaching a screenshot of the error.
    Is this firmware related? Didn't find much on the web.
  • Lance15
    • Jun 2015
    • 1071
    Re: HP CM3530 error 49.1805
    Have you updated the firmware? HP continually fixes 49.xxxx related errors with new firmware releases. If firmware doesn't resolve the error, then, more than likely there is a corrupted print job sitting in a que somewhere.
    • c3110
      • Jun 2019
      • 16
      I remember updating the firmware somewhere in April because I couldn't make the machine Scan to Email using Gmail, can't remember if it was the latest firmware or not. I will check when I get to the machine.
      • Zeldaman
        • Mar 2011
        • 946
        • c3110
          • Jun 2019
          • 16
          Saw that too on HP's support website. Will try to update the firmware and see what happens.
          I also found a procedure to do a "Cold reset" by using a combination of buttons when turning on the machine, maybe it helps.
          • c3110
            • Jun 2019
            • 16
            It has the latest firmware.
            Also noticed a bunch of other errors.
            • Lance15
              • Jun 2015
              • 1071
              For the 30 errors:
              30.01.41.pdf
              • Lance15
                • Jun 2015
                • 1071
                58.04.pdf
                • c3110
                  • Jun 2019
                  • 16
                  For the 30 errors:
                  [ATTACH]43219[/ATTACH]
                  Thank you for the attached PDFs.
                  I spoke with the company that sold us the machine and they'll send us a new formatter board for start.
