HP 602 laser
  • davebtech
    • Apr 2015
    • 176
    HP 602 laser
    Customer just called said they have a circle with a line going through it on machine ... never herd of this any help thanks Dave
  • 1stcavvet
    • Apr 2015
    • 231
    Re: HP 602 laser
    tear in the fuser film GOOD LUCK
    • 1stcavvet
      • Apr 2015
      • 231
      Re: HP 602 laser
      that's if it's on the prints if they mean on the display ----then they're stuck in the start-up. usually they turned it off and back on again(could have had a power outage) either way you have to reinstall firmware could be hhd replacement then firmware update all depends how hard a hit it took. and like I said GOOD LUCK
      • Lance15
        • Jun 2015
        • 1086
        Re: HP 602 laser
        If it is a circle with a line going through it on the control panel, the logo in the middle is of a person unplugging the power cord, meaning, DON'T unplug the power cord when this logo is on the control panel.
        +1 on 1stcavvet second post about what the problem may be.
        • davebtech
          • Apr 2015
          • 176
          Re: HP 602 laser
          This was a red circle with line going through power cord looks like this goes away and machine goes ready.but occasionally paper tray 2 will say close tray. But it is closed.checked side tray sensors looks ok ...??? Anyone see this ?
          • Lance15
            • Jun 2015
            • 1086
            Re: HP 602 laser
            HP RM1-8424-000 Paper Feed Shaft Assembly, Genuine (M9229)
            Had one do this and it took me while to figure out. I found the tip of one of the sensor flags broke off so it wasn't being detected by the sensor.
            Sent from my SM-G955U using Tapatalk
            • davebtech
              • Apr 2015
              • 176
              Re: HP 602 laser
              [QUOTE=Lance15;798195]HP RM1-8424-000 Paper Feed Shaft Assembly, Genuine (M9229)
              Sent from my SM-G955U using Tapatalk[/QUOTE
              On the tray flags or inside right side flags ? Thanks for replying Dave
              • Lance15
                • Jun 2015
                • 1086
                Re: HP 602 laser
                The sensors where this assembly is located. There is a sensor board and the sensor flags are on this assembly. When the tray is inserted, or the tray is filled, the sensor flags on this assembly interact with the sensors on the sensor board above.
                It's not noticeable until this assembly is removed.
                • davebtech
                  • Apr 2015
                  • 176
                  Re: HP 602 laser
                  Are we talking about paper out flag or paper tray flag?
                  • Lance15
                    • Jun 2015
                    • 1086
                    Re: HP 602 laser
                    The sensor flag tip that was broken for me was the Paper Sense flag in the picture.
                    • davebtech
                      • Apr 2015
                      • 176
                      Re: HP 602 laser
                      [ATTACH=CONFIG]43441[/ATTACH]
                      Thanks for hanging in there with me on this one, Does this tray insert sensor sense the tray being inserted or the paper amount paper in the tray? Thanks Dave
                      • Lance15
                        • Jun 2015
                        • 1086
                        Re: HP 602 laser
                        When the tray is inserted into the printer.
